Lepro WL1 AI Smart RGB Wall Lights with LightBeats Music Sync, LLM AI Generated Lighting, Color Segment DIY, Voice Control Via App, Wi-Fi & Bluetooth LED Light Bars for Bedroom, 6 Pcs with 2 Corners
  • 【Lepro AI LightGPM 2】 - Smarter Lighting Made Easy. Lepro LightGPM is large language model trained by color psychology and lighting design knowledge, it allows you to create professional lighting effects without needing to learn these skills yourself
  • 【 Easy to Use】 - Effortlessly control lighting with your voice. Share your activity or mood, and LightGPM will create the perfect ambiance for you using color psychology and lighting effect design, without the hassle of browsing and clicking on apps again and again from tens of different colors and scenarios
  • 【Controlled by Voice Prompt】 - The Lepro+ app features an integrated voice assistant, making voice commands a breeze. LightGPM analyzes speech to adjust brightness, change colors, and control lights within seconds. Also compatible with Alexa and Google Assistant
  • 【AI Generated Lighting by Facial Expression Recognition]】 - This RGB wall lights provides lighting options that perfectly complement your emotions through facial expressions or vocal instructions. Snap a selfie, upload it on the Lepro+ app, or simply say your mood to enjoy personalized lighting that reflects how you feel
  • 【LightBeats Music Sync】 - Experience dynamic lighting that syncs with music rhythms, transforming any space into an energetic and mesmerizing environment for parties or dancing
  • 【Billions of Trillion AI-Generated Scenes】 - By recognizing your emotions and voice commands, LightGPM generates up to 10 best lighting effects from billions of trillion potential lighting effect combinations to offer the best professional designs. Whether you’re hosting a holiday party, seeking relaxation, or immersing in the gaming world, each scene is meticulously crafted for a seamless and immersive lighting experience
  • 【Seamless Control, Anywhere】 Manage multiple devices effortlessly with our “Lepro+” App. Whether you’re at home or on the go, you can effortlessly turn light strip on/off, adjust brightness, change color temperatures, set timers and more - as long as your lights are connected to Wi-Fi
  • 【Personalize Your Wall Your Way】 - Our RGB wall light kit includes 6 wall light segments, 2 corners, 1 controller and 1 adapter. These corner lights have 2 different orientations, allowing for more flexibility and convenience in creating various shape combinations as desired. You can firmly install the wall lights by sticking the adhesive to any dry, clean surface in your home
test relpy test reply test relpy test reply
Dndndnd v dhdndjdjrmnmr
NowJjjkkkkkkmmuijbhjio
It’s a very nice post. Thanks.
Dieirjjfeujendnnfffgrf
