- [WLED Compatible] - Each LED node is equipped with two built-in WS2811 ICs (one for RGB lights and the other for white lights). The commercial-grade IC-chipped design allows seamless integration with WLED software. (Note: The output voltage of the Lepro original power adapter is 29V, and the input voltage of the string lights is 24V-30V. To connect with WLED, you will need to purchase a separate 24V WLED controller and 24V power supply units)
- [Works with Alexa] - You can also control it with voice commands through Alexa or Google Assistant, making it an integral part of your smart home ecosystem. Please note that the phrases Alexa can recognize are limited. For example, there is no utterance for adjusting brightness and color simultaneously as per the official Alexa guide
- [Bluetooth and Wi-Fi Enabled] - With Bluetooth connectivity, you can access most of the app features like DIY, On/Off, AI Voice Prompt, add to Favorites, and Schedule/Rules, but you won’t be able to control the lights outside of Bluetooth coverage or connect to Alexa. With Wi-Fi connectivity, you can access all app features and connect to Alexa or Google Home
