- [Smart Permanent LED Lights with RGB+IC (Independent Control) LEDs] - You can set each bulb to a specific color individually and create a myriad of lighting effects. This addressable smart lights do not come with a remote control, as it only offers a few fixed modes. We have released more exciting features and DIY designs on our app, which is continuously updated. We hope you will explore more with Lepro
- [Upgraded Dedicated 2200K-6500K Tunable White Light] - Choose any shade of white light, from incandescent-like true warm white for accent lighting to daylight white for security lighting. The white LEDs are individually addressable, so you can set just some LED nodes to warm white while others remain off, or only light up every 5th or 6th light. (Note: dedicated white light cannot be used in combination with RGB colors due to the current firmware version. But you can also create patterns with mixed white light in the DIY-RGB page)
- [Lepro AI LightGPM 2.0 - Smarter Lighting Made Easy] - Lepro LightGPM is a large language model trained on color psychology and lighting design knowledge, allowing you to enjoy smarter lighting effects without needing to learn these skills yourself
- [AI Voice Control. Easy to Use.] - The Lepro app features an integrated voice assistant, so there’s no need to connect to Alexa. Simply share your activity or mood by typing or speaking to the app, and it will suggest the perfect lighting effects for you right away
- [WLED Compatible] - Each LED node is equipped with two built-in WS2811 ICs (one for RGB lights and the other for white lights). The commercial-grade IC-chipped design allows seamless integration with WLED software. (Note: The output voltage of the Lepro original power adapter is 29V, and the input voltage of the string lights is 24V-30V. To connect with WLED, you will need to purchase a separate 24V WLED controller and 24V power supply units)
- [Works with Alexa] - You can also control it with voice commands through Alexa or Google Assistant, making it an integral part of your smart home ecosystem. Please note that the phrases Alexa can recognize are limited. For example, there is no utterance for adjusting brightness and color simultaneously as per the official Alexa guide
- [Bluetooth and Wi-Fi Enabled] - With Bluetooth connectivity, you can access most of the app features like DIY, On/Off, AI Voice Prompt, add to Favorites, and Schedule/Rules, but you won’t be able to control the lights outside of Bluetooth coverage or connect to Alexa. With Wi-Fi connectivity, you can access all app features and connect to Alexa or Google Home
MeCxvbgs vhggdcgsave
